F
fastnova
Hello, im a gas safe engineer and im having a nightmare with a britony 2t pilot problem..
I was called to the heater which had a water leak due to the burner staying on after the tap was turned off.. (burner was beading with gas)
So i installed a complete new gas water section to the heater and all seemed to be fine, after 2 days the pilot started going out, this has now continued for several weeks and happens almost 1-4 times a day. There seems to be no pattern to this, as in water being used or wind ect. It will go out even if the heater is not being used...
Ive tried everthing i can think of with this problem now, the heat exchanger is fine and in good condition, the flue is fitted correctly and sealed, the case seal is fine..
*Before the change of the part, the customer never had pilot outage, only in bad weather once or twice a year*
Ive done all the checks, gas pressure and water pressure.. Ive adjusted the slow ignition screw several times to make the heater ignite as soft as possible and still no joy..
Has anybody ever had the same issue as this and found a resolution?
Ive been a gas engineer for 16 years and worked on hundreds of these heaters replacing all the parts in the heater and never had this problem before?
Any help or ideas with this would be greatly appreciated.
Many thanks..
Many thanks..
