sadssandiford
Hi all usual symptoms;
Pressure ok when central heating off, shoots up to 3 bar when central heating on with usual water out of external pressure releif pipe!
Been told its Expansion Vessel that has failed!
Trouble is on Worcester Bosch 23i Greenstar Juniour, expansion vessel is part of boiler mounting frame!
As my flue goes out of boiler and straight through wall above boiler there isnt enough space to remove expansion vessel!
Boiler installation paperwork says if not enough room the boiler has to be taken off wall to change Expansion Vessel!
My question is cant you just disconnect horizontal part of flue from the elbow, slide flue out of way through wall, change Expansion Vessel and reconnect flue? Seems alot easier than taking boiler off the wall!
Any help much appreciated
Brent
Brent
