Charge for plumber
View the thread, titled "Charge for plumber" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi there
My shower is leaking, coming into the kitchen, and I have a trading standards approved plumber from the buy with confidence website coming out on Tuesday. He is charging £100 inc vat for call out inc first hour and then £60 an hour inc vat after that. I have looked online but can’t determine if this is a good price. I have no idea how long this job will take. Online I see that some people charge fixed amounts for jobs, even leaks. I wanted to go with this guy because he is trading standards approved so hopefully he is not a cowboy. Is the charging amounts about right? I have no idea.
Please help, thanks 😊
😊 I have managed to take the tray off but not a lot to report...I guess I could run the water and see what happens?
I’ve just run the shower full pelt all over the tray and nothing is coming through.
If the photos in the previous post are representative I think the search needs widening as what you've shown under the shower doesn't look wet.
Is it a pressurised heating system? Are you having to top up the boiler frequently?
Can you get a camera and some light in to the space where the pair of copper (heating?) pipes is?
What you want at this stage is someone with an endoscope that can be poked into the voids to see what's going on.
@Chuck I am not 100% sure what a pressurised system is but I have a combi boiler and I don’t think they are the same thing.
@king of pipes. Ok the photo you showed me with the red ring round the hole, after taking the shower tray side off, there is a gap in the floor by the wall. I poured some water into the gap and sure enough it pours through the hole in my kitchen ceiling. Result! But I am really confused. You can see on my second photo there are drip marks down the wall out of the hole in the kitchen ceiling. But my kitchen never has drip marks on it. Also the area around the gap by the shower was dry when I took the shower tray side off, even though I had a shower this morning. Any ideas how I can chase this further? The area is wet now because I poured water down the gap but I suppose I could let it dry completely for a few days and then have a shower and then check the area straight away afterwards? Or any ideas of things I can say to the plumbers to help them in the right direction?
@king of pipes also something else that occurred to me. The photo you put a red circle around, that hole is actually outside the shower so whilst if you poured water through that hole, it would then go through the gap and through the hole in the kitchen ceiling, how on earth can water be dripping from outside the shower? But it makes sense because that area is green so water damage. Could it be the screen is leaky but they have just redone the silicone and I left it 48 hours before using the shower.
What you've learned is that if you pour water through the floorboards some will soak into the plasterboard and the rest will move to the lowest point, i.e. the hole in the kitchen ceiling.
Unfortunately, you've now made diagnosing the problem much harder because its not going to be easy to distinguish between the effects of the water from the real leak and the water you've poured into the ceiling.
Please see my last post.
It's difficult to be sure but it looks likely that tray is not sealed behind screen profile.
Screen is also sealed internally which it usually shouldn't be.
The scale/scum rising up joints on screen and glass on outside edges is another sign that water is building up inside shower profile.
With screen end profile sealed inside and out and not behind means that water will collect in the profile and leak through.
If you spray the corner while observing underneath then you'll likely see it pour through.
I see lots of attempts to better seal the screen loins but it often makes it worse and the only correction involves removing screen
If the plumber added silicone to insides of screen then I would find some instructions for that (or similar) screen and point out where it says not to.
See what they do but I think a discount on proper repair that covers the callout would be fair.
I don't like to cause issues for other plumbers but this Is a lesson they need to learn
If all they did was replace what was already there then I think its fair to pay full bill
Oh dear, maybe I should contact the plumbers and tell them what I’ve done and leave well alone for a few weeks or even a month or so or does it not work like that? I think I’ve probably done everything I can do now with everyone’s help?
Is water penetrating though the wall trim in the corner this should be siliconed and screwed to the tiles? then sealed where the shower screen meets the trim and in the corner, then on the outside of the trim only theres always a risk of leakage there if not sealed correctly at the time of installation.
A little tip get yourself a water spray bottle fill with water and little food colouring just enough to colour the water, spray against the left hand trim inside and observe externally for any water leakage if you find it ? you then have grounds for a reduction in the plumbers bill or a future repair, a through cleaning of the shower area wouldn't hurt either can you get your hands on a domestic steam cleaner ? These work well on dirt and grime a little white vinegar added also helps ? Regards Kop
No, don't leave it for a 'few weeks or even a month'. Eventually the damp due to the leak will start causing rot and it is not going to get better on its own.
The best thing you can do OP is find a good plumber and make friends with them. Local is extremely importand and You either want a one man band or a very small firm. Someone like Dynorod can be sending different guy every day. Different guy = different result. The guys you had, no disrespect to them, but after getting them out you shouldn't be pulling off shower tray plinth and doing tests yourself. You are paying lots for plumber's time in order not to have to worry about any of it. If they couldn't deliver that I would settle their charge (sounds like £160 ) and try someone else next time. Young is not necessaraily an indicator of inexperience but your guy needs to have had at least 3-4 years on the tools and if they look 16 that just won't be possible. I would get on checkatrade and find reviews that mention one or two names only, reviews for exact type of issue that you have. They might be busy for a week they will almost certainly charge for investigating but why not book them provisionally with agreeement if you sort it to ring them a day or two before to cancel. When you do find someone who brings results pay them on time, don't dispute their rates, don't take the mick by asking them to look at your lightbulb or whatever expecting them to do free work or call expecting a free troubleshoot over the phone. Good guys are busy and value their time. nothing more off putting than a customer who asks for alot of "favours" and never offers a penny.
Thanks for everyone’s ongoing help. I’ve decided to stop looking at it for now for fear of making it worse. The plumbers are back Wednesday after the bank holiday so I’ll be back with more tales...👍
So the plumbers came back this morning and say they don’t think it’s a plumbing issue. They said that there is nothing more they can do than what they have already done (which is redo the silicone). They say the tray isn’t moving and maybe it is leaking down the side of the shower screen but that’s not a plumbing issue. A friend of a friend knows a good plumber so maybe I will get them out? Or I could go back down the property services route. At least I’m having a bath each morning and there is no more water leaking
Lol no! I will try my friends plumber and see what they say
So I thought I’d give an update.
The story so far:
Identified a leak coming from the shower tray through the silicone through the kitchen ceiling using plumbers Maddox Plumbing. They replaced the silicone but shower still leaked. They came back, didn’t know what else to suggest and left.
Next, a friend of a friend is recommended. He arranges to come out on the Friday. Doesn’t show. I send a casual text the week after asking when he might be able to come out. No answer. To be honest I’m reluctant to chase people anyway so I leave it.
Get another plumber recommendation from another friend. He comes over, shows me with a Stanley knife that part of the silicone hasn’t been done properly. Puts the shower over the silicone. After a while, it starts leaking. Arranges to come out on Wednesday (just gone) to replace silicone. Doesn’t show.
This last guy seemed to know what he was doing so I will give him a week to contact me but if no joy, I’ll be looking for plumber number 4…
A question to all the plumbers out there, I don’t want to chase because surely it makes me look desperate and it’s bad if a tradesperson can’t keep their word when they arrange to do some work. What’s your view on this?
A question to all the plumbers out there, I don’t want to chase because surely it makes me look desperate and it’s bad if a trades person can’t keep their word when they arrange to do some work. What’s your view on this?
Well, I'm a spark and I suspect that most areas have a shortage of plumbers so they can focus on the bigger jobs ......... I know that to be the case in my area.
I've never been so busy that I've had a problem keeping up with everyone, but then I am quite organised. I do know numerous tradesmen that are poor at getting back when they say they will with the result that people probably chase them more often.
Not keeping an appointment is poor customer service indeed, but I doubt any tradesman will be offended if you chase. I note my piano tuner and dentist now remind me the day before my appointment - presumably they have experience of people not being in/showing up. When I worked in a contracts firm and was urgently waiting for a technical response from a supplier I would chase very hour if I had to.
As for seeming deperate, you're trying to get your shower mended and you're willing to pay, not trying to get a romantic date (presumably) 🤪, so looking desperate is not something I'd worry about. Probably your plumber is trying to keep everyone happy and tends to be following whoever is chasing him harder/seems most in a hurry and if he thinks you are desperate he is more likely to show up.
The issue as I see it is do you really want to use someone who can't so much as advise you if he has to miss an appointment? If he's the best of a bad bunch, then the answer would seem to be 'yes' however.
Sounds like a typical story every other customer tells us. Heard numerous times of plumbers leaving in the middle of appointment to get something and never returning! In your case I would most certainly be getting the original plumbers who charged you for sealant work back to seal it properly. Sounds like you are almost there! Good luck
Just an update this end for those who gave advice/following. The sealant has been redone but it is still leaking. Checked the tray for hairline cracks and it seems to be leaking from the same corner. I will stick with the same plumber until this is resolved and this company have good reviews. It bugs me though, I’m really busy with work and he is busy with customers too so why am I being asked to give a reminder text to this guy to remind him to come out later in the week? I’m a customer! Work with a diary. I shouldn’t be reminding you that you have my job. All ranting aside, I have faith this will eventually get sorted and I’ll let you know the outcome.
I suggested it on page 3 and 4 but its looking more and more likely that tray is not sealed behind profile.
The fix is to remove screen, seal tray properly and re-fit screen.
I dont know if thats the case but i would put money on it!
Ok so I’m really starting to struggle now. I am also interested Knappers in where you are based. I am in southampton. The plumber was supposed to come over this week and didn’t. I told him I really needed to sort this out. He sent me this text:
“It may be worth talking to your insurance company. Feel we’ve done our best but where it’s been installed incorrectly and siliconed in side there is a chance what ever we do won’t work simply because of the poor install originally.
If they require a quote for a rip out and new install im happy to help. Other than that I don’t think we will solve the issue due to original install. Sorry.”
All he has done so far is redo the sealant. He has not even taken the tray out. He was supposed to come and look further at the shower and decide what to do next. Instead he is telling me to contact my insurance company for a refit and he will put in a new shower?! When he hasn’t even taken the tray out? He is saying the shower has been installed incorrectly but he never said that before. He told me that where it had been siliconed inside, it was a pain but he could dig that out. Now he is acting as though it’s not possible or too much work.
Have you said you want to remove the tray you know it might break and your happy to accept the liability if it does ?
Thing is Shaun, it’s been a nightmare to get the guy back. When he first came over, he was all up for sorting it out. He said he would definitely be over this week and he hasn’t (again). I need someone who is prepared to get this sorted for me even if it’s going to be a right pain in the bum. That is a good tip though and I will mention it to the next person who comes to look at the shower
On the surface it was possibly a small job, an on the way home job. The reality is that it's a much bigger job and now it's probably fitting it in with the work he has on the books at the minute.
But the issue is communication. If the above was the case then he should have said, this is what it needs to fix it properly but I'm not available for at least 6 weeks due to current workload.
I'm on with a bathroom and been given a list of things 'whilst I'm here' to look at. A bit annoying as it's such a regular thing but I explain, if i have time it's not a problem but chargeable, if i dont have time i will book it in on my first available time slot.
The other issue you have is that it's been done wrong from the start, once somebody starts pulling it to bits to do it properly you dont know just what you will find.
Hope you get sorted.
I'm in Midlands so a fair way from you I'm afraid.
If the tiles are good and not blown or falling off the walls and leak is from the corner where shower screen is (which is common) then I wouldn't be taking the tray out.
I would remove the screen and the sealant all round the tray, clean and thoroughly dry.
Either clean up old screen with razor blade or replace with new. You will clearly see with screen off if it was incorrectly sealed as there will be a gap in the seal where the screen profile was.
Then its just a case of sealing around the (clean and dry) tray before refitting the screen, it won't hurt to fit the screen a day after sealing the tray but I often do same day (with caution . Most screens ask for sealant on the OUTSIDE ONLY so that any water that gathers in the profile can drain freely back into the tray.
This is a fairly common fault that I've seen many bathroom fitters make even (and especially) on newbuild sites. It's a chunk of work for what is a simple fix and I usually charge a days labour.
I've tried other 'fixes' over the years like drilling and forcing silicone into the gap but find the above is the only acceptable option for me.
Of course this may not be your problem but as taking the screen out is going to be part of any further work then it won't hurt to take it out and have a look?
Reply to the thread, titled "Charge for plumber" which is posted in UK Plumbers Forums on Plumbers Forums.
Sonicboom,
king of pipes,
