View the thread, titled "checking the FSD on boilers?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
sterry_12
hi lads, im doing my acs gas training and was just wondering how to test the FSD on boilers? can you just knock the gas off? checked a cooker hotplate which was easy enough but never checked a boilers.
thanks.
run boiler, turn gas off, boiler should keep sparking, or stop, should go into lockout.
Time the fsd. About 60 seconds on boiler, may differ with appliance so you'll need to check MIs.
Also you may want to check gas valve to make sure it's not passing.
Stick u-gauge on P1, close isolation valve and wait until fsd closes. Open and close isolation valve again. If the gauge drops, the valve is passing.
to do it correctly you need to confirm that the gas is shut down at the gas valve, so you can either perform a mini tightness test at the applaince or a tightness test at the meter. This is what they are looking for on your ACS or Gas Safe inspection.
are we talking combi boilers? they dont have a fsd they have a detection probe and circuit and as stated turn the gas off ,if we are talking a fsd like a oxygen depletion sensor that would typically have a thermocouple,pilot injector with depletion port and a spark electrode what you would need to do is simulate a dirty/blocked pilot assembly using a large, flat bladed driver put it between the thermocouple and pilot jet the thermocouple should chill and shut down
An auto ignition boiler should shut down in 2 minutes I.e. a modern condenser should lock out in 2 mins.
There is a TB about it
i dont think I can remember ever doing that unless i suspected there was an issue with a smell of gas or suspected a faulty gas valve
Reply to the thread, titled "checking the FSD on boilers?" which is posted in Boiler Advice Forum on Plumbers Forums.
