View the thread, titled "Chrome 15mm female compression tail" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dwsubc
I am replacing some old imperial radiators with smaller modern radiators. I don't want to move the old pipes coming up through the floor. I plan to fit right-angled Drayton TRVs and lockshields on top of the existing pipes and then run short lengths of chrome pipe between these valves and the radiator. The chrome pipes might need a few slight bends to take up any misalignment.
I could fit the compression radiator tails I got with the TRVs and then use a chrome coupler to connect to the chrome pipes. However, this is going to look messy.
Is there a chrome fitting that will screw into the 1/2" BSP radiator tappings and leave a 15mm female compression fitting on the outside? I could then fit the chrome pipe directly into this.
Many thanks in advance
Dave
Just get straight 15mm chrome compression couplings remove nut from one side and screw straight into radiator tapping with a bit of ptfe tape on thread then go straight to 15mm chrome pipework on other end linking to valve
Little tip,it may be easier to put the small piece of chrome pipe in the coupling first,then you can use the chrome nut on the fitting to turn fitting into radiator thread
Adjustable Radiator Valve Tail Compression - NoLinkingToThis, Where the Trade Buys
Had you considered using straight valves rather than angled?
If you've got enough room you could fit straights directly into the rad and then use a standard CP compression elbow and CP pipe to connect to the existing rad pipework
Mark
🙂Thanks for all the tips here.🙂
The union idea looks good and it fits OK in a spare radiator I am practising on. Also, the spare chrome nut and olive can then be used to connect the chrome pipe to the TRV.
I did look at the extending tails but I would need to put some bends in the tail and I was unsure whether they would still seal OK.
I don't really have room on all the radiators for straight valves.
Thanks again for all the tips - I can now order the parts with a lot more confidence than I was feeling before. Once I get one done I will post a foto to show how it turned out.
Dave
Reply to the thread, titled "Chrome 15mm female compression tail" which is posted in UK Plumbers Forums on Plumbers Forums.
