View the thread, titled "Circulating problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
BoilerPro
Sime Oil fired boiler, probably sealed system. Industrial unit, not home. Boiler reaching temperature but nothing to rads. Pressure low but filling loop making no difference. (Have seen this before and we call it an Irish solution to an Irish problem, i.e. it has all the equipment for a sealed system but is actually an open system). Circulating pump appears to be working in so far as it is spinning. Have traced system as much as is possible and can't find anything like a motorised valve, so it seems that either the pressure is too low as indicated by the pressure guage (but can't rely on it as stated above) or the circulating pump is making all the right moves but not actually working. Is this possible, or do they just stop? Also, whenever I've used a filling loop to refill system I have always felt a rush of water while tap is open, but feel nothing this time. Customer did bleed rads and said there was "a lot" of air in one of them but rads full now. What am I missing?
Kevin
Thanks Steve. So, the circulating pump might appear to be working but actually not?
Reply to the thread, titled "Circulating problem" which is posted in UK Plumbers Forums on Electricians Forums.
