C
coldwrench
Leaks were causing my heating system to loose nearly 1bar of pressure a day.
After replacing the expansion vessel, a leaking pump, a leaky rad, 6 leaking radiator vents/caps, leaking hot cylinder aav, a clean with Fernox F5 and the addition of a leak sealer additive - I am now down to loosing <0.1 bar a day. Pressure is only lost when the heating is on.
I could live with this but I would like to try eliminate the remaining water loss.
One remaining area I think could be leaking is the aav at the circulating pump.
It's difficult to know if the pump aav is leaking as it is at an inaccessible location in the boiler. I wouldn't like to try and get my hand in there to check for water while the boiler is at temp😱. I am thinking of closing off the pump aav (manual system bleed is fine for me). Before I do this I would like to get others thoughts as I am not a plumber. (There does seem to be a lot of "crud" around the vent itself).
What problems could I cause by closing the aav at the pump?
Any thoughts would be gratefully appreciated.
Thanks !
(The boiler is a 10 year old Vokera Mynute 20SE).
Thanks !
