View the thread, titled "Cistern flush valve body retaining ring/nut" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Pumber01
Hi folks,
I'm having difficulty removing the retaining ring/nut from external base of a toilet's cistern. The chap who fitted it either used some form of adhesive or had forearms like Popeye!!! I have attached an image below, and am wondering whether anybody knows whether B&Q, Homebase, etc, stock a plastic spanner that would engage the thin, vertical strips on the ring/nut.
Pumber
have you not a pair pump grips ?
i have 2 spanners that fit these but they are not an off the self item they came with the valves.
I'm with Sonray - I've got a plastic spanner thingy that came with a Variflush drop valve. Have you tried a strap wrench? (Boa or similar)
. It's about the only thing that are useful for 😀
Mark
ive nether had a problem with these before big pump pliers is more than enough??
Reply to the thread, titled "Cistern flush valve body retaining ring/nut" which is posted in UK Plumbers Forums on Plumbers Forums.
