T
The Shadowman
Hi All
First time on the forum, and I would like some advice, please.
I have a cistern with a side inlet valve (Fordham I think) that has worn out and needs replacing. I would prefer to replace it with a modern, quiet type, e.g. Flushmaster. The problem is the current valve is 22mm and all the modern quiet sort appear to be 1/2". Is it possible to fit the 1/2" type to the existing 22mm inlet supply using an adaptor?
If the above is not possible I would need to get a replacement ball-cock type, and I am being confused by the terms "part one" and "part two" etc. If I have understood correctly, a toilet cistern should be "part two", the problem I have is when I search for part two, l only see 1/2"
Any advice offered will be gratefully received
Thank you in advance
