View the thread, titled "Cleaning system with direct feed hot water tank" which is posted in Bathroom Advice on UK Plumbers Forums.
R
Ratty
I've got an old heating system in my house, Baxi back boiler and 8 rads. Some of the rads have been getting warm at the top but cold at the bottom. I took one out and flushed it through. It took nearly an hour with a hose before I could get a clean flow! I though I would run some Sentinel X400 through the system but I've hit a problem. After draining the system and re-filling I found the hot water tank emptied when I drained and on refilling the hot water is brown. I'm assuming from that that the tank is a direct feed tank and not an indirect. I assume then that the only way to clean the heating system properly will be to swap to an indirect heat tank and then flush the whole system? I don't mind changing the tank as the current one isn't insulated apart from one of those 'blanket' type things that strap around the tank.
The existing cylinder is most likely a Primatic (single feed) one, is there an F&E cistern in the loft or top of a cupboard ? As you say, best to get it replaced but take care if your current system is gravity circulation.
Flush all rads first & replace cylinder before using cleaners.
Yes, there is a cold water tank above it. Not sure if it's a single feed as you say though. I'm away tomorrow so I'll take a look on Thursday. Going by the pipes coming out of the boiler, 4, 2 x 22mm and 2 smaller (one pumped for rads) I assume it's got the two 22mm pipes feeding it? If I change the hot water tank which is best, copper or a stainless steel tank? Looking at the B&Q Tradepoint catalogue stainless is slightly cheaper but is the saving worth it?
If I fit a new F&E tank for the heating system what would be the minimum size needed? There's no room in the cupboard with the current tank so I would have to put it in the attic and the hatch is pretty small. I would imagine it wouldn't need to be big as it's only to keep the small heating system fed.
You are going to need a plumber for this one I am afraid there are just too many pit falls, apart from the fact that to replace a cylinder the person carrying out the work should hold the Part G ticket. A lot of the cylinders sold can not be used with gravity primaries, it may be time to upgrade to fully pumped.
Reply to the thread, titled "Cleaning system with direct feed hot water tank" which is posted in Bathroom Advice on Electricians Forums.
