Guest viewing is limited
clicking sound from programmer and boiler
View the thread, titled "clicking sound from programmer and boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
K
karazi
Hi.I have a problem with clicking sound coming from programmer and boiler itself.Problem occurs after i run out of gas (token meter,top-up type).After some time when water in tank starts to heat up programmer switches of itself.Sound seem to be disapeering when water is hot.then everything works fine,I have hot water and central heating is working fine.
Programmer is Barlo Products and model is EPR-1
Boiler is Trianco Gas,model W.M. 30/40 R.S. with water tank in cupboard.
I also have wireless receiver Watts Milux RF Thermostat.
Does anyone have any idea what is causing this situation and know solution for it?Thanks for help.
Now i have different problem.Programmer is not clicking and water is hot.But it keeps going off after couple of hours so water in tank isnt heating up and heating isnt working.Could this be faulty programmer.Do you know any other programmers that would replace my and would fit same backplate without the need of re-wiring?
Reply to the thread, titled "clicking sound from programmer and boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
karazi,
IDCHAPPY,
