Clogged drain pipe
View the thread, titled "Clogged drain pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
My washer machine drain pipe will back up with the drain hose from the washer, but when I put the hot water line in the drain, it will run forever and not back up. I have tried just about everything with the same results. Thanks in advance.
Can you post a photograph of the pipework you're trying to use, please?
Reply to the thread, titled "Clogged drain pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
Ed Hnat,
Ric2013,
