View the thread, titled "Cold downstairs radiator problem" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Last winter everything working fine. Switch on this winter and 2 downstairs radiators do not work, others downstairs and those upstairs fine. Turn off all radiators except one cold one, it heats up okay. Turn back on other radiators and it goes cold again. Do same for other cold radiator and this one only gets luke warm, however it stays luke warm when others turned back on. Eon, who have maintenance contract, says it needs a power flush. Any thoughts please.
my first thoughts were trapped air, but you would have shifted that by closing the other rads to get the problem ones working.
possibly needs flushing, but the rads do work when others are closed,
suggests a balancing issue.
has anything been done to others radiator to have affected the system balance?
do Eon want to do the flush for free or charge??
Reply to the thread, titled "Cold downstairs radiator problem" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
