Thanks for the reply, manifold feeds 3 rads and has 6 pipes so it has both feed and return?Could be blocked or the micro bore blocked. You could try putting some system cleaner in, and see if that helps. If not a drain down and remove and check manifold.
Reply to the thread, titled "Cold rad and manifolds" which is posted in UK Plumbers Forums on Electricians Forums.
