View the thread, titled "Cold Radiators Downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
J
Jonathan@9
Ok so I have standard 3 bed house, boiler downstairs, pump and tank on the first floor, working with 30 year old mircobore pipes, the radiators have twin entry valves.
The radiators are hot upstairs, cold down. Last week I turned down the heat on the radiators upstairs and saw an immediate improvement downstairs. This did not last...
On Friday night I turned all the lock shield valves down a turn on the upstairs radiators to force more water downstairs, no result then - but yesterday morning (Saturday) good hot radiators downstairs, today cold or luke warm again...
I have lots of hot water - the central heating out pipe is very hot..
Any help appreciated
How can i double check the pump? has a large silver screw head on the front and a white control on the side, this is a little hidden due to the position - what does this control do?
also remove the screw when pump is working, carefully and gently insert a screwdriver to feel the shaft spinning, a small amount of water will come out, this is normal, if its tons of water then pump is also knackered
Ok so i removed the screw on the pump, felt it working, replaced the screw and my wife shouts these radiators downstairs are rather hot. We have a result, maybe a short term one, but seams like maybe the pump has issues.
You could have freed the pump up or it could have been airlocked depending on its position. Could you post a photo of the pump installtion please?
Reply to the thread, titled "Cold Radiators Downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
