Hi guys,
I have a little problem at a customers property that really I just want confirmation that I am going down the right route(don't want to keep having to go back & cost her an arm & a leg lol). I have attached a picture of the pipe work set up to help illustrate my point.
Basically its a aged system I was called out to a noisey pump, the pump was an old myson that sounded like it was gonna take off so, naturally I changed the pump for a grunfoss 15-50 (by the way I did notice discharging water before replacing the pump). When filling up the system after replacing the pump I wanted to check that water wasn't discharging from the vent on the f&e when the pump was just running cold water to obviously try and rule out an overheat issue. water was found to be discharging when cold from the f&e vent pipe so then my next port of call was to the pipework and this is what I saw.
So obviously I am looking at the cold feed and vent set up and thinking the cold feed should be on the return side of the heating system or at least not anywhere near as close as it is to the vent as it is in the pic. I am I right in thinking this?, if not any ideas what else could cause discharge into f&e even when COLD? (pump set a MIN by the way same as previous pump).
Cheers
Cheers
