Hi All,
Wonder if you can help, went to look at a job yesterday, quite straight forward, moving a indirect 1200x450 cylinder and replacing the cold water tank,questions are-
tank is 100 gal, old absestos, incorrectly supported and bowing the ceiling, this needs replacing but i think 100 gal is to big, is a 3 bed with one bathroom, soon to be a 5 bed with two bathrooms. So first question is do you think a 70 gal coffin tank will be a better option?
Second question is, all pipes off of tank are run in 28mm, cold to cylinder, cold to house, and hot out of cylinder, i would like to replace this all in 22mm, i know this means volume is cut slightly but think again 28mm is over the top?
Any help apreiated, just needed some other opinions!
Thanks, Andrew
Thanks, Andrew
