View the thread, titled "cold water storage tank" which is posted in Bathroom Advice on UK Plumbers Forums.
stuart17
hi
can any one advise me if a cold water storage tank is large enough for 2 power showers 1 x Aqualiser stream 10-18 liters per min and 1 x mira event xs power shower 14 liters per min. Dimensions of tank =1100mm x 560mm wide x 600mm tall.
many thanks
That is about 270 liters. And you want to draw off 32 liters per minute. That is about 8 minutes shower time.
But the tank starts to fill as you empty it, so you would have to know the make up rate to give a more balanced idea.
It also depends of course how long you spend in the shower.
You can add in a diversity factor if it applies i.e That both showers are not used at the same time, so the time for each individual shower is longer before it empties the tank.
thanks berni
do you think it needs a second tank??
Hi Snake
Is it possible for both showers to be on at the same time and if so for how long ?
Yes both on approx 10-15 mins at a time.😡
Also how is the hot feed.
Very good🙂
oil fired system boiler
Reply to the thread, titled "cold water storage tank" which is posted in Bathroom Advice on Plumbers Forums.
