View the thread, titled "College Question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
U
UpTheCov
Hi, I've reccently started my city and guilds level 2 and have been asked to work out the pressure of the bottom box (all will be explained in the link) Could someone explain this to me as to what formula I have to use, Thanks
Diagram [DLMURL]http://img530.imageshack.us/img530/3959/diagram.png[/DLMURL]
.3 bar😕
3x9.81=29.43Kn/m2
1 bar=100,000N/m2
14.7psi=1 bar
This is intensity of pressure
3x9.81x0.5mx0.3m=4.41kN
This is total pressure
The last reply's misleading, in that he's multiplied a pressure by the area upon which that pressure is being brought to bear. The result of that calculation is a FORCE. Mind you, so many C&G questions are v. badly written, and you may be marked correct for this answer. 0.3 bar is the answer, 4.41 psi in old money.
Bobble.
Hi Upthecov
I take it you have both the JTL and Treloar (3rd ed)?
I too am currently in year two at College and have both of the above but the latter also covers level 3 and explains all this sort of stuff alot better and in depth...
hope this helps.
J
Hi all, many thanks for the replies. This is what we were told today;
To work out the total pressure you need to know the IP (Intensity of pressure)
which is head x 9.81 kPa
Therfore the sum is 3 x 9.81 = 29.43
then times this by the area of the required box, so 29.43 x 3 =
88.29 kPa
Not sure if this is the same as the previous answers in a differnt form?
Reply to the thread, titled "College Question" which is posted in UK Plumbers Forums on Plumbers Forums.
