J
jonpeck
Hi Long story short I have just moved into a property and I am not sure weather there is an actual problem or not. The Issue is the shower is not adjustable as there is just one constant temperature and it runs out after 6/7 minutes but goes scalding hot then stops all together. No cold water comes out. Also no hot water comes out the tap. So surely it should just run cold as it runs out of hot water? Or is the mixer valve at the boiler or shower not working? There is also a 25 gallon water tank in the loft. dsss
