M
Masood
A little bit of a puzzler here - Vaillant combi boiler with a Honeywell RF programmable room stat. Customer says she comes home from work to find the rads warm, even though the programmer is set to "off". No symbols on the boiler display at the time.
I had a look at the programmer, it is synched to the receiver, and works as it should. There are no DIP switches on it to alter RF frequency, so I can't fully rule out the possibility of a neighbour's programmer switching it on, but customer says there's no pattern to it - it fires up at random. Also the flats are not new-build, so not very likely that they all have identical units.
The only discrepancy I have found is that the bathroom thermostatic mixer valve is letting by - cold water comes out on full hot setting, even after hot water has been isolated from the boiler. Do you think this could be back-feeding into the boiler and triggering the flow switch, and in combination with a faulty DV, is warming the rads? Seems a bit unlikely to me, but I can't find anything else obvious. British Gas changed the DV a few months ago - she has the receipt - so that is pretty new. Any ideas, folks? Ta!
