I think some do offer intelligent pre heat so it remembers when you use hot taps and pre heats at a similar time to following days.Would be good if you could time it to be on during times hot water will be used and off at night or at work.
Yeah it does make a difference.If preheat is available on a non storage combi is there much difference in hot water availability than without preheat?.
Can it possibly cause issues?That was my slight concern if caused issues long term if left on.
I've seen diverters prematurely fail, and i'm sure it'd shorten a boilers life. But by how much, is unknown. It's such a variable factor.Can it possibly cause issues?
Fit one for an oldish lady in a loft she requested the pre heat be left on. As complained the last boiler took too long for water to get hot. Awkward for here to ever turn the pre-heat off with where its located.I've seen diverters prematurely fail, and i'm sure it'd shorten a boilers life. But by how much, is unknown. It's such a variable factor.
Sure it'll be fine. With the lengthy manufactures warranties these days as well it'll be covered for 5/7/10 years dependant on manufacturer.Fit one for an oldish lady in a loft she requested the pre heat be left on. As complained the last boiler took too long for water to get hot. Awkward for here to ever turn the pre-heat off with where its located.
With the such small storage of water I imagine the expansion is very minimal. Never had any issues myself, but then again I rarely leave the feature on.If a PRV is fitted on the incoming mains, is there not a danger that the pressure will rise excessively high due to expansion as there is no HW flow during preheat?
Similar to my situation never really leave it on. Just on this one installation.With the such small storage of water I imagine the expansion is very minimal. Never had any issues myself, but then again I rarely leave the feature on.
Reply to the thread, titled "Combi boiler pre heat" which is posted in Boiler Advice Forum on Electricians Forums.
