combi boiler, pressure continuously increasing.
View the thread, titled "combi boiler, pressure continuously increasing." which is posted in Boiler Advice Forum on UK Plumbers Forums.
Try turning off the cold feed for a while and turning on a hot tap to release the pressure. Could simply be **an internal component related to hot water costing around 150 pounds** although you need someone to fit it.
*Edited to not name the component just in case
If you find the filling loop/valve to be ok, There is a test you can carry out to confirm whether it is an internal part that has a pinhole between the CH and MCW.
1. Turn off call for heat on programmer while testing.
2. Drop system pressure back down to 1.5bar .
3. Isolate CH flow and return valves and hot water outlet valve.
4. Leave for a day and see if the pressure has still risen.
If the answer is yes you will need a registered engineer to change the affected part.
Reply to the thread, titled "combi boiler, pressure continuously increasing." which is posted in Boiler Advice Forum on Plumbers Forums.
Juman islam,
Ready Steady Gas,
