M
MidJeff
hi can anyone help had a look at an excalibur 100 combi boiler, pressure gauge needle moves when you tap it' and also when they call for hot water all is ok but when they turn off hot water the central heating kicks in even tho they're not calling for it does anyone have any ideas on what the problem could be? something else there seems to be a link in between the flow and return on heating with 15mm ballafix valve turn off in the middle cheers
