View the thread, titled "Combi boiler timer question" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have an Ideal Logic 24 Combi boiler and the manual timer has stopped working, it was losing time but has completely stopped moving now.
If I manually rotate the timer dial the boiler kicks on as it should.
I can get a replacement from a local store and was wondering if this is an easy install and is it likely to fix the problem.
That cover is a functional cover and not decorative.
To remove it you must be qualified to ensure it is sealed correctly.
Reply to the thread, titled "Combi boiler timer question" which is posted in Boiler Advice Forum on Plumbers Forums.
