combi boiler watere pressure gauge below 1
View the thread, titled "combi boiler watere pressure gauge below 1" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
corinnemunoz
hi
can anyone help i have a worcester combi boiler. they water gauge is always below 1...we have looked under the floorboards but we cant find a leak...any advice would be greatly appreciated
thanks
hi mike
thanks for answering
i havent topped it up i wouldnt know how to do that...since it was installed it goes from 0.5 to 1.0 at the highest
thanks
If you haven't topped it up it's not leaking. Ideally it should be on about 1 bar when it's cold so have a look at the instructions and see if you can see how to top it up. Alternatively get the engineer to do it and show you how next time it's serviced
Mike
Just spoke to my husband, he tops it up 2 to 3 times a week to 1 bar and pressure rises about 1/2 of 1 bar when its on
anyone got any idea ?
Expansion vessel has an internal leak for a guess ( i am not a plumber). The leaking water is vented externally so you may not notice it. I had the very same problem with a worcester boiler and changing the vessel cured the pressure problem.
hi thanks
i called the guy out who fiited it and he found a leak under the house
thanks again
Reply to the thread, titled "combi boiler watere pressure gauge below 1" which is posted in Boiler Advice Forum on Plumbers Forums.
corinnemunoz,
corinnemunoz,
