View the thread, titled "Combi boiler with unvented cylinder" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
mcniven
Hi lads,
Someone asked me about this today and I was not really sure how to answer it. This person has a combi, but wish to connect a unvented cylinder to this for flow rate reasons.
I've never thought about this, and there is probably good reason is it not common practice. I can understand the flow pipe being zoned to cylinder via programmer.
Anyone heard of this before?
It is possible to convert a combi to a system boiler i believe.
However you would undoubtedly negate any warranty.
How big is the property? And what is the budget. Alpha cd50 is a combi with a built in unvented cylinder. Massive thing size of a washing machine. Could be worth a look. Only 50litre i think but impressive heat recovery and awesome flow rate
No reason for it to negate the warranty. No different to zoning a combi as far as the wiring back to the combi goes.
I did one recently. Customer moved into a property with a combi but not enough flow rate so I fitted a 150l unvented to the system for them. This solution was actually suggested to them by Worcester.
Hi lads,
Went to a job a commercial guy had put in a few years back ... He'd fitted an unvented cylinder and combi on the same hot water supply! Why? I thought! Crackin hot water supply though!!
done a few like this combi feeding kitchen sink and cylinder bathroom . tee the heating flow and do an s plan one zone for htg other for cylinder but remember to fit an auto bypass - boiler works like a system boiler but kitchen has instant hw from combi.same principle for twin htg zones on combi
Reply to the thread, titled "Combi boiler with unvented cylinder" which is posted in Boiler Advice Forum on Plumbers Forums.
