View the thread, titled "combi boiler wont fire" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Maybe fan seized or pcb
does it make any sound when turned on,check not switched to stand accidentally
I would follow the sequence water(pump spinning) air (fan/air pressure switch) working........then on to the gas valve...?
Check the solder joints on the main pcb sometimes ( in electronic terms ) they get dry joint which means, solder has come away from the pcb, its self very hard to see with naked eye but use a magnifyer if so you can just drop a solder irin on them for couple of second( works on potterton supreama)..
as puddle sways likely fan,pcb or lwps gunked up(that's the low water pressure switch)
Reply to the thread, titled "combi boiler wont fire" which is posted in Boiler Advice Forum on Plumbers Forums.
