dannyd
Hi all,
I've just moved in to a new house which has a combi fitted but appears to have some very strange plumbing in place. The DHW output is connected to the kitchen tap only. The remaining hot taps are connected to a cylinder.
CH output from the boiler is connected to a mid position valve which feeds the CH circuit (single zone) and the cylinder and this side of the circuit appears to be wired as a Y plan.
I'd like to convert this to combi as its a bit wasteful to heat the full tank of water as it very rarely gets used. I think the reason its been done like this is because the boiler is in the kitchen at one end of the house and the cylinder is in a bedroom at the other end.
Is is possible to reuse the existing flow to the cylinder currently on the CH circuit for DHW? I was thinking of connecting this to the DHW output on the boiler and then at the cylinder end connecting the flow to the hot water outlets, bypassing the cylinder.
Would this work or would it take a long time for hot water to reach the other taps?
Thanks for your help
Danny
Danny
