E
Ermintrude
It's a condensate pump!
Needs a pump does it? Not sure about that, but the veissmann boilers say they have it
Some pumps can take both and Viessmann's combine them. The only issue's afaik is an air break and high temp plastic. but Viessmanns allow you to come off their condensate trap with ordinary o/f pipe although their hose from the trap is high temp rated to get the kitemark so read of that what you will.
Things are changing quickly in development these days and the regs take a while to catch up.
But can you get a tundish that starts 21mm and 21mm the other side
Think he meant prv into tundish then condense
Into the plastic pipe after the tundish
How would user know if it was condensate or prv tho?
That's what I was thinking
If there is a steady trickle it is the prv. The condensate is syphonic.
But it's a combined condense and prv
I get calls from custards because logic plus says "pump over run" steady trickle or full blow off, symphonic is what my phone would be like if they were watching tundish discharges!
Only combined after the tundish before its just the prv
What I have done in the past is prv into tundish short piece of 22mm copper into hep 2o valve which converts to plastic then t in condense pipe after hep valve then run in
1 1/4 to soil ,drain or soak away
Oh ok, so you have fitted these vitodens boilers? And this is what you do? I just don't see in the MI'S a prv connection
Reply to the thread, titled "Combined condensate and prv." which is posted in UK Plumbers Forums on Plumbers Forums.
