H
horseunderwater
In 2006 we had a new Bathroom fitted top to bottom.
The chaps who did the job, guaranteed to stop any water leaking as we had previously had many a leak from the old fitments.
They put in one of those loos that has a small compact cistern with a push button flush and this sits against the wall. I had to replace the internal flushing fitting last year as it broke. Your help was great.
However, it still leaks from underneath where the 2 pieces join even though a new rubber donut ring has been replaced recently. It has been tightened as much as we can, but still it comes out. Not as bad as it was, but enough that there is a problem. Now call me daft, but the cistern looks like there is more rounded edges at the back and the front is flatter? Does that make sense? Is it possible to fit one the wrong way round? The inflow pipe is on left as you look at it straight on, but the inflow pipe comes up from the right and crosses over with a flexi pipe to this and an inline shut off valve. Could this be why it fails to seal correctly? Any advice appreciated.
