Guest viewing limit reached
Compression blanking ...
View the thread, titled "Compression blanking ..." which is posted in UK Plumbers Forums on UK Plumbers Forums.
WaterTight
Subscribed
Such as for removing rads from valves for decorating or capping off an unneeded w/machine feed...
Do you just need a cap and blanking disc? No sealant, ptfe or washer?
I know people talk of putting coins in there etc - not to sure I want to do that - but I've seen some caps which come with rubber washers instead of blanking discs - at least one of which I've seen leaking. I've also seen caps on there own.
But in terms of doing it properly - is the best, most reliable, thing to do to use simply these two, tightened like normal compression?
you can use the blanking cap and a washer, i would prefere to use the fibre washers that are intended for use in flexible hose connections as they are designed to seal on a compression fitting. or actual wash mac washer.
or you can on rad valves use the blanking disc and a compression nut.
forgot to add that i offten use a doc on a rad valve with a compression nut and olive, good idea to have a few made up anyway to aid draining down when no doc are fitted to system.
Yes I use blank nuts with fibre wahers, or sometimes a 5p and washer if just temporary. If you try and just use PTFE on the threads it often leaks.
Hot washing machine valves not in use should be capped of with a 3/4" blank nut, someone is bound to turn it on by accident while they force something under the sink and then flood the house.
Reply to the thread, titled "Compression blanking ..." which is posted in UK Plumbers Forums on Plumbers Forums.
WaterTight,
Phil,
