For one reason or another, I seem to have had some pretty poor quality compression fittings of late and had to rely on boss white to seal. Not sure if its poor olives (brass v copper). Anyway, I'm about to replace my indirect cylinder and while cold feed, and coil feed and return will require new connections and hence be new comp fittings, I would like to use the existing 28mm top connection (hot water feed). Can I expect problems due to tolerance differences between fittings in which case perhaps I should renew the pipe or should I rely on boss white.
Thanks for any advice.
