View the thread, titled "Compression fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
No hand tight then tightened 3/4 of a turn is enough , if you strangle it to death you crush the olive onto the pipe this can cause it to fail , a smear of pipe jointing compound around the pipe before sliding it into position and tightening is the way . Kop
Reply to the thread, titled "Compression fittings" which is posted in UK Plumbers Forums on Electricians Forums.
