PowerFlusher2
My mate is looking at having a new combi boiler installed (the old one is not a condensing boiler) and one of the installation quotes says that the condensate will be taken from the room to the outside and connected into the existing roof rainwater giuttering downpipe (which is actually the other side of the fence dividing the back gardens - which is another problem). Is it 'legal' to route the condensate down the rainwater downpipe? I know that allowing the condensate to 'flush' into rainwater guttering is not allowed but can't find anything about running it into the downpipe, in the same fashion you could into a stink pipe, if there was one available.
it all depends on the drainage system the property has. If its a combined drain so the foul and rain water go into the same system then it can be connected. If the rain water and foul are seperate drains then the rain water goes into a surface water drain and you can not connect to it. You can use neutrailsers but they cost alot to keep replacing/servicing.
As regards the pipe crossing a boundary i would think its not advisable without permission.
Upvote 0
just phoned the water company. the area is one where foul water and rainwater are taken away down separate drains so untreated condensate down the rainwater downpipe is a definite no, no, GBP5000.00p fine for sending untreated condensate down a rainwater gulley!
Upvote 0
As already stated you need a combined drain and if memory serves me correct you also need to have an air gap or mini hopper head/tundish on the condensate to prevent any backfill of condensate . Check the MI's
Upvote 0
