View the thread, titled "condensate into square down pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
efficient
Hi all, just viewed a boiler install for next week. 32mm condensate pipe will have to run outside into a black square down pipe... anyone seen an adapter/boss for a square down pipe, if so can you post the link
Cheers
Just get a y piece, is it combined rainwater and drainege system though plus dont forget to leave a air break in it
i guess at worst you could put a rain water head in though as previous post if mcalpine do a connector you could use that
as you need to have an air break/gap your best to get a branch and elbow of said RWP and fit the branch with the elbow pointing straight up and the 32mm waste pipe sitting just above the elbow.
Reply to the thread, titled "condensate into square down pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
