View the thread, titled "Condensate soak away" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Chrisjg
Hi, today I changed my condensate pipe from 21.5mm to 32mm (due to freezing) and routed it out of the loft conversion where the boiler is and down the outside wall to around 5cm from the ground. The water then drops into a hole about 30-40cm deep filled with gravel to soak away. The pipe runs directly down the wall and therefore isn't far away from the brick work where the water comes out, is this ok or does it have to be 50cm away from the house? I have read conflicting stories and would like clarification so I can adapt the pipe work if needs be.
Thanks, Chris.
The soak away should be 500mm from wall and pipework run into it,you can buy soakaway units with lime chippings from plumbers/builders merchants
If boiler in loft conversion,why not fit a small condensate pump and pump into soil stack or plastic waste
you could use a con de aciders thingy that fits on con pipe run to ground ,so not acidic
Reply to the thread, titled "Condensate soak away" which is posted in UK Plumbers Forums on Plumbers Forums.
