Blackspaven
Getting a new combi boiler fitted soon as my 14 year old one is on the blink and this is gonna be condensing where the current one isn't. Question is, what would be my options for getting rid of the condensate?
All I've read seems to indicate that internal disposal is better due to potential freezing, but I may be a bit limited. Is there any way of attaching or cutting in to the 110mm horizontal straight waste pipe running from a toilet in the next room which is about 1.5 metres away out the wall to the drains (very loosely, with those self cutting water filtration taps in my mind), otherwise I'm thinking I'll have to go straight out the wall and down to the waste drain.
Also, as it's a victorian house, is there any realistic issue with the existing drains being concrete and the acidity of the condensate eating them or the joins at all... would NOT want a lovely bout of subsidance thanks to boilers going green! (heard it's about as acidic as ketchup, but thought I'd ask those who know. 🙂 )
Cheers
EDIT: Sorry, forgot to ask; am I presuming correctly that pumps are only needed if the run for the condensate pipe is over a certain distance? If I had to rely on going outside and running down the flank wall, I think it'd be a straight diagonally down run of about 2.5 metres, tops.
Cheers
