I’ve been having a few pressure drop issues with my heating system. One problem already diagnosed and sorted (thanks to this forum) was a leaking EV at the valve end (replaced) but I am still seeing a pressure drop (albeit slower than before 1.5 -1.4-1.3bar) and wanted to ask a question....
I have a Worcester 40CDi Regular this is a condensing system boiler (4 years old but previous owner maintenance very minimal if anything).
I’ve dismantled the condensate line and put a jug under.
The odd thing is even when the boiler has been not been firing for several hours it still produces condensate.
overnight boiler off at 17:30. no CH at all (which i have valved off anyway)
no water cylinder heating until 07:45 but when I checked at 07:30 before the boiler fired the condensate jug was overfilling (so more than 0.5litre) but the boiler hadn’t fired at all and was showing 16degC (it’s in the garage). The pressure was down by ~0.5bar
so again boiler was off after the morning water heating enidng at 08:30. Waited an hour and then replaced the jug. At 10:30 the jug was empty but by 1600 it was overfilling again (temp 20degC) and Boiler wasn’t due to fire until 16:45.
So the question is should a condensing boiler be creating condensate when it hasn’t fired??
I am 99% sure the answer is no, but just wondered if because the boiler was on electrically could it make a difference? I don’t see how... doesn’t condensate only come from the boiler firing?
The condensate line is standard drop/gravity based (there is no pump or anything on the line).
Am just thinking could it be the HX is letting by?
There is also a manual valve inside the boiler by which the boiler can be emptied straight to condensate line - could that be leaking?
Or is what I described normal?
I could turn the boiler off electrically but I don’t see what difference that makes.
The condensate isn’t a constant trickle all the time it seems to batch the condensate in glugs so for an hour or so nothing, then a dump of water, then trickle from the dump then another dump - I’ve read elsewhere that the Worcester does “batch” the condensate but not sure if that is true?
really appreciate any thoughts or comments.
