View the thread, titled "Connecting to newly fitted water meter, in a field" which is posted in Bathroom Advice on UK Plumbers Forums.
W
wally5460
Hi can someone please offer me a bit of advice, my dad own a smallholding with farm buildings on it he is having mains water run to a location next to the main barn. bristol water have dug a trench to run the pipework and are coming to connect to the mains just inside the boundry of the land. I have been asked to run the pipework(approx 150m long in mdpe) and have it ready to connect to the meter when they come to install. My questions are........
1. what size connection will it be on the meter 1/2" or 3/4"?
2. do i need to put metal tags at 1m intervals along the pipe to aid future detection?
3. what type of connector is used to connect to the meter (screwfix page /item no. would be a great help)
4. are there any other special requirements ie dc vales etc.
I have good basic plumbing skills and knowledge but am usually fitting bathrooms and the radiator so a quick bit of guidance would be a great help.
you will need a MDPE/copper adaptor kit, i think to a meter they are normally 1/2" but they do a 3/4" kit too i think they are only a few quid.
150m is quite a distace for service size pipe, out of interest what size have they told you to use? i should think a minimum of 50mm?
you can buy protecter line its more expensive but has metal in the pipe to aid in detection.
ensure pipe has a minimum of 750mm of cover and cover with 150mm of sand
screw fix product code 65438
Hi Wally, stokecity advise is spot on. If you can be there with a tenner in your hand and a bit of flannel the guys fitting the meter will do the bits you mention and may well have detection tape with them. If you need to do it make sure you fit an insert in the MDPE.
They should have the fitting to connect the water meter, normally the meter and fittings are supplied by water board. Just confirm with them what size pipe you are installing as you may need to reduce down to 25mm if that what the meter fittings connect to. As reguards water pipework , have you confirmed that there is no ground contaminates? if not then protector pipe would be a good idea as this would stop any contamination of water supply and as mentioned has the added bonus of a zinc barrier that may be detectable.Only problem with this is its alot more expensive than standard mdpe pipe and fittings.
Protect against tree roots. The 2007 foot and mouth disaster in Surrey was due to this. You'd also need to consider the co-efficient linear expansion too.
Reply to the thread, titled "Connecting to newly fitted water meter, in a field" which is posted in Bathroom Advice on Plumbers Forums.
