View the thread, titled "Connecting values to towel radiator help needed" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi there. I’ve installed a new towel radiator and I’m trying to fit the valves but I’ve come unstuck and need some help.
I’ve bought new angled valves to replace the old ones but I can’t connect them. I think I’m missing something.
They are the right size to screw into the bottom of the radiator, but the valve head is too big so it’s not a tight join
the radiator comes with a connector but the valve dont tighten on them.
See pictures. Apologies if this is something really obvious. Am I missing a connector?
Thanks in advance
Your picture in post #5 is how you do it.
Slide the valve onto the smooth tail, yes it can just fall off again, but then you tighten it with a spanner and the copper olive is compressed - this not only makes a water tight seal but it also stops the valve falling off!
Reply to the thread, titled "Connecting values to towel radiator help needed" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread starter
Joined
Location
Somerset
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
Thread Tags
DIYnovice1,
cjg,
