View the thread, titled "Connection for parallel tap port" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all,
Happy Sunday…first poster here so pls be gentle 😊
I have a Nuie Arvan ARV828 basin mixer tap which I am trying to connect H/C feeds to. The inlets are 1/2in BSP parallel threads.
The issue I have is I am wanting to properly seal the inlets with more than just PTFE/Fernox. However I cannot find a male coupler long enough to be able to use with an O ring to get a good seal. All standard male couplers are too short so don’t seal the O ring properly.
Any ideas as to what connection would work best here?
Many thanks
Image of the tap ports is attached.
I use loctite 55, it’s great and never have a problem.
You could use thread sealant eg loctite 577; but it’s quite expensive and loctite 55 is more useful for general use.
Are you saying it's designed for an o-ring at the bottom of each port - are they supplied?
Had that not been the case, I would have been sealing it on the outside surface with a fibre washer!
If so looks like you need at least 8 threads worth of depth.
There are extra length tank fittings, or this adapter:
though I don't know how the flat profile at the end will align with your o-ring !
Reply to the thread, titled "Connection for parallel tap port" which is posted in UK Plumbers Forums on Plumbers Forums.
