View the thread, titled "Constant water flow noise coming from the stopcock." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
I’m renovating a house and I can hear what sounds like water flowing through the seizes up stopcock. I have checked everywhere including the loft but the tank is disconnected and there looks like a new combi has been recently installed anyway. There are no tap or toilet leaks and no visible ceiling water marks. It makes this noise throughout the day when I’m working. However sometimes it stops (rarely).
I’m think that this 1930s property has shared water feeds with the close and perhaps the noise is other water users. Is this assumption likely?
It’s driving me bonkers not knowing the cause.
Can any of you experienced guys throw any light on this.
In any event, you need to get the stop-cock freed-up and working properly.
Next you need to see whether the noise stops/changes when you close it. Do you have a water meter? If so, what is it doing? Does the noise stop when the neighbours are out/asleep?
There are no water meters visible in the close and the neighbours I have spoken to have no idea other than they have a stopcock in the cupboard.
Difficult to know if it stops at night as the property owners haven’t moved in yet.
Until I can find another way of shutting off the water I don’t really want to apply too much force to the stopcock. As it stands now it is proper seized up and probably needs replacing. Unless I can turn off further down stream I’m a bit snookered.
A competent plumber will have the kit and skills needed to replace/repair the seized stopcock without causing a flood. Assuming you are not sharing a private supply, I'd advise seeking advice from your water supply company about the location of their stopcock, what they know about how the individual properties are supplied, and where they think that your responsibility for leaks starts.
Reply to the thread, titled "Constant water flow noise coming from the stopcock." which is posted in UK Plumbers Forums on Electricians Forums.
