View the thread, titled "continental rad valve?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
John t
Customer has a radiator valve with a compression fitting for a (what looks and feels like) a 16mm pipe, been told by plumbing merchant 16mm is a continental size. Problem is I need a seal/fitting to take up the extra 1mm, any ideas on a supplier. Worst senario he'll have to buy new rad valves but as yet haven't double checked the thread connecting to the rad,
thanks for reading
is it not 15m soft copper it comes on a roll like 10mm pipe does. only thing i can think of is a 1/2 to 15mm end feed coupling the old style copper pipe had a thicker outer wall so may get away with it ?? second idea is use a drift of flearing tool to widen a piece of 15mm and slip the 16mm inside it an solder it
Reply to the thread, titled "continental rad valve?" which is posted in UK Plumbers Forums on Plumbers Forums.
