Continuous noise from indirect water cylinder
View the thread, titled "Continuous noise from indirect water cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have moved into a house with a Joule Cyclone CY200L indirect cylinder in my loft. Recently it seems to continuously be making a noise, as if it's filling up or heating up, I'm not sure which.
The thermostat on the side is set to 55, when I turn it below 50 there is a click and then the noise stops. But it doesn't come back on at all. So the noise from the cylinder is either continuous or silent. I've read that I should have the temperature set at over 55 to prevent bacteria in the water but I'm worried that it's costing me a fortune because it never seems to stop running!
Any advice would be appreciated.
Is it possible the immersion is permanently switched on, and the thermostat you talk about is for the boiler?
I'm not sure. The thermostat is literally attached to the cylinder so I'm certain it's for the storage temperate, not the output. But I could be wrong. I'm still getting to grips with the heating layout in my new home. There are two digital, wireless thermostats - one controls the radiators upstairs, the other downstairs. Then there's a Danfoss controller in the airing cupboard that seems to link to the boiler downstairs and the cylinder in the loft. I'm not sure if the thermostats override the Danfoss or vice versa. I think I'll get an expert in who can (hopefully!) walk me through it.
Reply to the thread, titled "Continuous noise from indirect water cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
mavroboy,
mavroboy,
