View the thread, titled "Control Stat Testing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
godsell4
I think the control stat on my boiler (Grant Multipass, Oil, Vented Indirect system) might be faulty.
If I set the dial of the control stat to 65C, the temperature at which it clicks off is about 70C and the temperature it clicks on is about 56C.
If I set the dial to 75C, it tends to click off at 82C and I have seen it click off at 88C, it then clicks on in the low 60's C.
Of course when it clicks off, the temperature still rises a few more degrees. But I have seen that when it clicks off at high temperatures such as 88C, the temperature rises a lot, getting to 107C one time.
Does this sound normal or odd for the control stat?
I am measuring the temperature using a Digitron 2202T by sticking the thermocouple into the same hole as the control and overheat stats.
Thoughts?
Im not sure the tolerances of accuracy but I expect yours is fairly within them
Reply to the thread, titled "Control Stat Testing" which is posted in UK Plumbers Forums on Plumbers Forums.
