View the thread, titled "Convection hot water not working" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
T
Triff
Hi All,
i just swapped out my hot water tank for a new one as it was about 1/3 full with limescale!!! Everything is connected up the same was it was previously apart from the loop from/to the boiler on the tank used to be 28mm pipe I've replaced with flexihose.
When I turn the central heating on the boiler fires up the pump goes and the rads get hot. When I turn the hot water on, I can hear the valve open, but the boiler doesn't fire. Feeling the pipes they don't seem to get any heat by the tank, (when the ch is on) but I can undo a compression fitting (in or out) and there is defiantly water in there! It's an open system, there is water in the header tank and I'm running out of ideas. I'm going to use the immersion heater for now, but before I pay for someone to come and have a look wondered if anyone had any other ideas on what it could be?
thanks
Please rotate your head by 90 degrees 🙂
Rogue Traders would have paid good money to have pursued the cowboy that installed that cylinder.
That is lethal get an EXPERIENCED,QUALIFIED plumber in asap
But no one as answered his question ! Why its not working ? come on guys stop taking the P--- and tell him ! Its the wrong size flexes.
I think that the curves on the flexi's are impeding the correct flow coefficient in the primary pipework.
I could be wrong though.
A question like that at midnight had to be a sparky on a wind up, until I saw the picture 🙂
The cylinders not rated for gravity, the flexies are not rated for central heating temperatures and the female iron connectors on the cylinder will have stressed the cylinder.
That's gonna be a real expensive diy job.
Looks air locked... Also if you say you hear the valve click are the white and orange... Besides it looks to be air lock. Try fitting an air safety value at the high point where the flex is at the flow on the cylinder
Please try and be a little bit constructive with your answers guys.
Difficult I know, but..........
An air bleed valve may help. Wished I could copy and paste you a link but I'm using a bb playbook and I'm not sure how to do with this one
Reply to the thread, titled "Convection hot water not working" which is posted in Gaining Plumbing Experience on Plumbers Forums.
