View the thread, titled "Cool Radiators Downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
R
Riz
Hi guys and girls,
I'm a first time poster so apologies if my knowledge comes across a tad green. My system is a standard boiler system (i.e. not a combi).
I've got an issue where my radiators downstairs are cooler than the ones upstairs. The upstairs ones are nice and hot but the downstairs are luke-warm.
I've had my local plumber out and he's flushed the system using his special flushing equipment.
I've also noticed that there's a bit of noise coming from the heating system, which I think emanates from the pump. However I mentioned this to my plumber and he thinks the pump is fine.
There's also one radiator that's closest to the hot water tank that has to be bled regularly (1-2 times a week). I don't know if this is relevant or not.
The house is struggling to get above 16C, even when having the heating on for a week. The house is fairly well insulated (the snow didn't vanish off the roof recently).
Can anyone offer any advice as to why my downstairs radiators are comparatively cold?
Thanks very much for the quick response.
I'll give it a go and let you know how it goes.
BTW, can anyone suggest a good brand?
Also my friend says that it might be that the rads upstairs need to turned off, then later re-opened to half way. Could that sort it?
Wilo pumps are also very good and a bit cheaper than Grundfoss, who from my recent experiences seem to be losing their market edge.
Found the Grundfos Alpha2 15/50 for £75 +VAT so ordered that as it's not much dearer than a standard pump.
My plumber's going to install it as soon as it comes in so will let you know how it goes.
Thanks!
Re: Cool Radiators Downstairs - The Problem Continues!
Thanks for the advice so far guys.
I've replaced the pump with a Grunfoss Alpha 2. Seems to be working nicely but unfortunately the problem still persists!
I'm beginning to wonder if it's got something to do with my Potterton Suprema boiler or the Danfoss TP75RF controller?
The boiler comes on for about a minute and then stops (flashing green light). After about 3 minutes, it starts up again (for another minute). Occasionally it looks like the Alpha 2 resets itself as all the lights come on, and then it settles back down to the right setting.
If it helps I've uploaded a couple of pictures of my set-up as well as a short movie of the problem to my MobileMe account: MobileMe Gallery
Any ideas greatly appreciated.
Thanks.
Possibly a silly question, but presumably you put the pump on the correct way round? In case you're unsure, there's an arrow imprinted in it's body indicating the direction of water flow.
Thanks for your response. Yes pump definitely the right way round.
I've done some more testing with Danfoss, the control unit manufacturers. Basically when boiling water for hot water, it seems to work fine...burns for about 7-8 minutes before pausing and then starting after minute. However when boiling water for central heating it doesn't seem to work.
I've noticed a wheezing coming from the boiler just before it stops burning when doing the central heating (it doesn't do it for the hot water).
I think conclusions tend to be the boiler as being an issue, but I'm wondering where the wheezing is coming from?
To be honest, I would have gone with balancing as the first and cheapest option. It costs absolutely nothing and can be ruled out very quickly. Your now down the price of a new pump and plumbers labour for what would appear to have been a perfectly good pump already. Before you spend any more money on it try the following:
Turn off water to hot water cylinder. Turn off all rads upstairs. Ensure room stats/trvs are set to high downstairs. Leave for a while and see if rads heat up. Once they do, turn back on rads upstairs and re-open cyclinder no more than one turn. It may take a little extra time to heat water for showers/baths etc. but will give you heat downstairs.
Also, you didn't mention whether you've always had this problem downstairs or if it is a recent problem. If it has always been this way it is possible that the pump is underspeced for the house. Don't assume the plumber who refit the new one bothered to check whether it was right for the job. If balancing doesn't work let us know the size of your system, e.g. number of rads, size of house etc.
Kevin
Hi Kevin and thanks for your input.
I should have mentioned (sorry) that I've already tried balancing the radiators.
The pump has been fine for the last 7 years and I've changed it to a Alpha2 15/50 which is what the previous spec was. During that process I had to drain the system.
I've got a 3 bed semi, with 4 radiators upstairs and 4 downstairs.
Hope that helps give more insight.
Hi Jim and thanks for your advice.
Would that also explain why the boiler cuts out with the central heating but not with the hot water?
Just to give an update my plumber came round today and fitted a new head unit of the 3 port valve (apparently the valve itself seems fine).
The house and the downstairs radiators are warmer, although it's taking its time to get up to a good heat (been on since 11:30am and only up to 18 degrees). I'll leave it on for another 24 hours and see if it gets up to 20.
The boiler still cuts out after 1:30mins so not convinced that it's all OK though.
Hi guys,
Thought I'd give an update.
Things are still the same, despite changing the pump, the header unit for the 3 port valve, the situation is still the same.
I even put in some Sentinal X400 to flush the system. Left it in for 3 weeks but still no change.
My plumber seems to think it's a blockage in the pipes downstairs and thinks that I need to replace the pipework. Seems very drastic to me.
Does anyone have any pearls of advice as to what I should try next? I'm freezin'!!!
I think I would have changed whole three port not just head
If on a drain down water black or sludge then blockage could be problem look at radiator first
Hi Jim,
Thanks for your input.
I thought the same about the 3 port valve but he checked it and said the valve itself was fine.
When I emptied the X400 out of the system there was nothing major in terms of sludge or anything. The system was flushed a few months ago by my plumber too.
have you got a de-scaller on the system pipe work at all?.
had one a few weeks ago, loostened of some scale somewhere and totally jammed the tube enough to remove the pump without draining down.
Hi Redsaw,
Thanks for your post.
Do you mean a physical de-scaler or an added one?
I added Sentinal X400 the other week, kept it in for 3 weeks and would have thought it would have solved any scale issue (unless you think otherwise of course).
a physical one or air seperator even.
if it were i, i would drain down, cut some sections and test for blockage.
may take 3/4 hours but rather get to the cause first time.
I would turn off hot water and all rads bar one (downstairs) turn on heating, now does that rad get hot? if so open all the other ground floor rads, do they all get hot? if they do then open the upstairs lockshield rad valves just 1/4 turn or less and see how that go's many plumbers/heating engineers dont have a clue when it comes to balancing a system, also make sure that the by-pass valve if fitted is not fully open, give it a try before changing anything, hope this helps, Martin
Gentlemen, thanks for your input. I'm going to start at the beginning and change the second half of the 3 port valve. My plumber changed the head saying the valve seemed OK, but unless that's changed too I'll always be suspicious of it.
It's a relatively simple starting point too. I'll keep you posted.
Many thanks!!
try cutting out the point where the cold feed from the feed and expansion tank meets the central heating system..........ive had 4 jobs in the last month with exactly the same symptoms and this point was blocked. don't spend no more money until you have treid this.
Reply to the thread, titled "Cool Radiators Downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
