View the thread, titled "Copper pipe below concrete floor" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello, first post here so hi.
I have taken up the floor in my kitchen and found that the copper pipes for the CH and gas have not been lined with tape then concreted over. This is obviously wrong, so I have removed them and plan to re-do using battens and ply to make a duct which will not need backfilling and the pipes run in the duct.
My question is, do I need to use coated / wrapped copper in the duct? The pipes will be sitting on the concrete, but at no time will be in contact with wet cement - would ordinary uncoated be OK or should they still be sleeved?
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
Reply to the thread, titled "Copper pipe below concrete floor" which is posted in UK Plumbers Forums on Electricians Forums.
