View the thread, titled "copper pushfit" which is posted in UK Plumbers Forums on UK Plumbers Forums.
pauls
anyone used them copper pushfit fittings are they any good.
got a job where i have 2 tails coming out of the wall connected to plastic behind/inside wall i want to T off the tails flow and return to put in a new rad.
thinking the pushfit copper might be a good option in this situation i dont want to apply heat to solder new Ts in, just incase the heat transfer affects the plastic fitting behind the wall and compression would look to unsightly on show
Ther ok providing the pipe is cut clean with no burrs and fully engaged, mainly used under sinks if dont fancy scorching the nice new kitchen cupboard.
Why not try Just for Copper cold solder with end feed fitting.
anyone here tried this yet ?saw it in selcos today not cheap
Got some from B&Q(quiet!!!)
I'm going to rig up some stuff on Sunday and pressure test it(Whilst hid behind a blast proof wall!!!!)
I'll let you know how it goes(If I don't get injured!!)
Tip pushfit straight couplings are very useful when doing tap tails 😀 Put tails in connect pushfit coupling then a bit of copper then the isolation valve. You then dont have the problem of undoing the tails as the pushfit allows the pipe to turn without undoing the tails 😀
Reply to the thread, titled "copper pushfit" which is posted in UK Plumbers Forums on Plumbers Forums.
